Last thing before having a running 350! Just need sum alternator help
Old Feb 6, 2011 | 01:34 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
Ok guys, i did the 350 swap, everything has been easy, ive just been making all of my connections and lines daily driver quality, new 700r4 tranny. Everything is brand new, except for my original crossfire injection 3 wire alternator.
My harness has the plug with 3 wires, and then an additional small wire that attatches to a small prong on the alternator, i hooked that stuff up,
however i just figured out, i dont have any wires running back to my battery for charging it
So could a guru enlighten me, from where exactly do i run a nice stout wire to my battery so that she can maintain proper voltage. Thanks, Joshua
Old Feb 6, 2011 | 02:39 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Last thing before having a running 350! Just need sum alternator help
The factory wire usually runs from a post on the rear of the alternator to the main battery post down on the starter.
If you wish you can run your own wire directly to the positive post of your battery or to a distribution block if you use one.
Old Feb 6, 2011 | 04:48 PM
thanks, i think i know exactly what post your talking about, ill c where it leads to on the starter and run a big fat wire from there to the battery, should i fuse it or not? Joshua
Old Feb 6, 2011 | 04:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The positive battery cable already runs to starter - no need for another "big fat wire".
Old Feb 6, 2011 | 05:11 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The factory doesn't fuse it but it's up to you. 100+ amp fuses cost a bit more than the small ones.
camaro71633
Sep 1, 2015 10:24 AM
Bob88GTA
Aug 18, 2015 03:31 PM
milk
Aug 10, 2015 06:26 PM
1nastygta
Aug 8, 2015 07:38 PM
