Check engine light wont go off
Old Feb 6, 2011 | 04:52 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Engine: TBI 305 STOCK
Transmission: 700r
Axle/Gears: 2.73?
I have a 89 camaro RS 305 tbi auto.
I noticed the check engien light came on a few weeks for no apparent reason as it was still driving fine.
So yesterday i took it too checkers too borrow there code scanner to check the code for whatever reason it said no codes where stored and the light was off. so i drove it around and what do you know it cam back on.
so i checked the code again and it still said no code. then i disconnected the battery for 5 min and reconnected it and drove around and it was still on
So the question is now what
Old Feb 6, 2011 | 11:49 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Check engine light wont go off
If no codes are stored, you'll need to have it checked while the code is active and the light is still on (leave engine running etc). With hundreds of different possibilities, nobody can guess what might be wrong.
Old Feb 7, 2011 | 11:52 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Pull codes manually. Maybe Checkers is trying to check with OBD2 or something. Grab a paperclip and read: https://www.thirdgen.org/service-eng...ht-error-codes
Old Feb 7, 2011 | 12:43 PM
dlsfbodyfan's Avatar
Car: 1990 Formula
Mine did the same thing for the longest time. It popped three codes in two was vac and fuel related <once inspected codes where wrong. The third very strange was a code for Chry I think it was which stumped the mech. Mines 90 formula with tbi. Best bet is what guy above me said let it run till light comes on stick the grand oll coder key under the dash and count the flash's. Also I tore out all but straight pipe from headers back if youve done the same that is a high possiable for why.
Old Feb 7, 2011 | 07:49 PM
mxxdude's Avatar
Car: 1989 Camaro RS
Transmission: 700r
Axle/Gears: 2.73?
ill try the paper clip thing tommorow, however for whenever the check engien light was on i realized the speedometer cable was real loose and the thing was bouncing around and shaky
and today it stopped working so i am thinking thats it if not ill try other peoples suggestions
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
