HELP Engines stalls during electrical load. 87 GTA dig dash
Old Feb 8, 2011 | 02:20 PM
onebadta's Avatar
Car: 89 GTA
Engine: 383, Accel DFI, stealth ram
Transmission: 700r4, 3500 stall
Axle/Gears: 9 bolt 370 gears
This is a new on on me. Just bought a 87 GTA Digital dash. Was going down the road last night and pressed the power window down button and the enginge shut off, and tach dropped to 0. depress the buttonn and the tach come back to normal and engine running. and this is not just when you press the window buttons. its prettymuch anything electrical. EX.rear defog, heater, signal lamps, etc. Ended up having to turn the headlights off and follow a friend to get where I was going last night. first thought was alternator, but it shows 14 volts on the gauge, and never seen anything act that crazy with a bad alternator. Maybe the ECM? I havent started checking fuses and wiring yet.
Thanks for any help
Old Feb 8, 2011 | 03:17 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Contains Antimatter
Grab a spare headlamp & socket.
Now, with the car parked and running, place the socket across the battery so it illuminates.
Did the car stall?
If no, it might be a bad connection at the starter.
Remove the cables from the starter, wire brush them so they look as shiny as they did in 1987, and wire brush the area on the starter, reassemble.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Jorlain
Aug 24, 2022 05:11 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Street Lethal
Aug 14, 2015 08:25 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
