rod bolt installation?
Old Feb 12, 2011 | 09:34 AM
greenturtle05's Avatar
Can someone give me some tricks to installing rod bolts. Also is it absolutely necessary to use a bolt stretch gauge when installing them? pics would be great too. thanks
Old Feb 12, 2011 | 07:52 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: rod bolt installation?
Swapping rod bolts is not something you want to do at home. Start by inspecting the rods, they should clean with hone marks on both ends, if you cant see the hone marks and see bluish/black marks or see the imprint of the back of the rod bearing on the machine surface the rods are going to be out of specs from hammering, and check for cracks. Then you want to check both ends of the rods on a rod gages usually attached to the rod hone. If the rods are out of spec you press the bolts out machine material off the rod and cap, reassemble and hone. We don't rebuild alot of rods, you can buy new rods as cheep as you can buy rod bolts and have them worked. On torquing you can use ARP lube and follow their directions. Torque loosen and retourqe three times and you will be OK.
Old Feb 12, 2011 | 09:04 PM
toomany's Avatar
Every time I've had rod bolts replaced...I've had the rods resized. Resizing them is not something you can do at home (well you can, but you need the propper equipment). In theory you could press the old ones out and press the new ones in, but that still isn't the correct way to do it. Machine shops use a rod oven to get the rods evenly heated to make removal/installation easier.
Old Feb 12, 2011 | 11:59 PM
Engine: 355
Rod heaters are for the small end of the rod on pressed fit piston pins.
Old Feb 13, 2011 | 07:08 AM
toomany's Avatar
I knew they used them for the small end. I thought they used them for the big end as well too.
Old Feb 13, 2011 | 11:59 AM
so What would you guys recommend doing when using the stock rod bolts? This is on a vortec long block.
Old Feb 13, 2011 | 01:19 PM
Engine: 355
They will be powdered metal rods with cracked caps so they can't be rebuilt.GM uses them in their ZZ4 and 604 crate engines. In new condition they are better than anything GM used in the past. You have two choices, if the housing bores check good reuse them as is(not recommended unless they are new) replace them. http://www.summitracing.com/parts/SCA-25700P/
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
red90IROCls1
Aug 25, 2015 06:56 AM
