Bad Starter?
Old Feb 13, 2011 | 12:56 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Bad Starter?
Just broke in my trans am yesterday.. It started up fine, I didn't put in any shims, the engine turns over good still.. Today, after fixing my distributor, and a few other things, when going to start it back up to adjust the carb, it made a horrible grinding sound from the starter.. So, I figured it had to be shimmed, went to part source, and tested it out..
No luck, same noise.. Removed the starter, the bendix seems to be hung up, i put a flathead screwdriver in a slot where the starter gear is visible, and tried pushing it out, it comes out about.. 1/8" and won't go any more.. Could this be the problem?
I made sure to stop before I damaged the ring gear.
Old Feb 13, 2011 | 01:34 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Re: Bad Starter?
Any time you put a starter on a Chevy. You should check the starter alignment before you use it. You probably already damaged the starter. try this http://www.marinemechanic.com/site/page169.html
Old Feb 13, 2011 | 01:46 PM
Kevman's Avatar
Engine: 2004 LQ4
Re: Bad Starter?
The starter looks more like figure two, with the end of the gear worn down.. I didn't try and start it while it was running though.
bbsr72
Sep 27, 2015 05:55 AM
FormulasOnly
Sep 10, 2015 09:07 PM
383cam
Sep 9, 2015 06:01 AM
Jlanz55
Sep 6, 2015 03:05 PM
Formula_88AE
Sep 3, 2015 01:47 PM
