Ignition ON, Fuel pump doesnt click
Old Feb 13, 2011 | 07:24 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
earlier today i noticed some fuses that didnt belong in there correct spot. so i red my chilton and put the correct amperages in the correct location. now the fuel pump doesnt click when you turn the key.. relay time? i was working under the hood during pouring down rain but not to sure that could have caused it. fired right up yesterday.
Old Feb 13, 2011 | 08:34 PM
jeff_blake's Avatar
Re: Ignition ON, Fuel pump doesnt click
did move the battery out and back in as well. i noticed the wire coming off the alternator goes to the battery. and in between theres a black cylinder with a small wire, and a big black wire coming off.
Old Feb 13, 2011 | 11:17 PM
jeff_blake's Avatar
anyone?
Old Feb 14, 2011 | 12:20 AM
s4l's Avatar
s4l
Car: None atm :(
Engine: :(
Transmission: :(
Axle/Gears: :(
That's weird. Did you try reverting to the old configuration of fuses for ***** and giggles?
Old Feb 14, 2011 | 12:21 AM
jeff_blake's Avatar
no but i tried every combo possible.. well almost. made me kinda mad, just installed new adjustable fan and such and then was like ah crap, wont start.
Old Feb 14, 2011 | 12:25 AM
s4l's Avatar
s4l
Car: None atm :(
Engine: :(
Transmission: :(
Axle/Gears: :(
Maybe the previous owner f***** up the fuse box somehow and it requires a different fuse than what Chilton says.. or maybe Chilton is lying! :runaway: :P
Best of luck, I've never heard of this before.
Old Feb 14, 2011 | 12:28 AM
jeff_blake's Avatar
wouldnt doubt me, i restored it for the most part, and did an engine rebuild, interior ect ect. alot of things were rigged. wouldnt think the fuse box is one of them, but hey who knows
Old Feb 14, 2011 | 12:32 AM
s4l's Avatar
s4l
Car: None atm :(
Engine: :(
Transmission: :(
Axle/Gears: :(
You'd be surprised. I had a friend who once did rig the fuse box.. don't ask.. I don't care to ever know... one of the slots went bad (dunno how) so he took one for something non important (I think a rear power window) and tore into the box and switched the wires. Who knows..
Off topic, but what did the interior resto cost?
Old Feb 14, 2011 | 01:37 AM
jeff_blake's Avatar
actually free, i was able to clean the whole interior and get the mold out, and re glued the door panels, looks stock again.. almost
Old Feb 14, 2011 | 02:38 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Check the inline fuse by the battery.
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
