Need to find an aircleaner base.. 350 Perf RPM Airgap
Old Feb 16, 2011 | 08:50 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Ugh... Made the mistake of buying an edelbrock Pro Flo before I read more info on them....
I have to get my car going for Saturday, exhaust is going on... I'm on the hunt for a drop base air cleaner.. Now, I have a 7/8" drop.. I'm looking for a 2" drop, for my 2 1/2" filter with an Xtreme K&N lid..
I have a Formula Turbo style hood, with the vent removed, with the insulation still intact. With just the carb it's pretty tight.. Anyone have any experience with this?
Old Feb 17, 2011 | 08:40 AM
Kevman's Avatar
Engine: 2004 LQ4
Re: Need to find an aircleaner base.. 350 Perf RPM Airgap
Nobody?
I tried a 10" Edelbrock, it was too high.. I'm going to try a 2" drop base, not sure if that will allow clearance for my choke horn..
Old Feb 17, 2011 | 08:51 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
My base is I believe a 2" drop from mr gasket. With a 4" or so high filter, it should clear, but barely. I have a cowl hood, but I remember one time thinking about going to a stock style hood and I think off the top of my head it would work. The air cleaner should have the flat provisions to clear the carb properly.
Old Feb 17, 2011 | 11:32 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I went with a Spectre 9" cleaner - is on the shelf at Autozone for $30. It's not drop base, but it only has a 2" filter so it fits just fine. The 2" filter actually allows more airflow than a 3", because since there's no 'drop', there's no restriction in flow. I had a drop base 14"x3" - but it dropped so much that there was only in reality a 1/2 inch area all around for airflow. Plus, the 14" rubbed my distributor wires. AND - with the drop base you have to use a 1/2 inch spacer ring, which is plastic, and breaks from the heat in a month or so, creating a non-filtered space for air to flow in.
The Spectre has only one small easily fixed issue - the lid kinda points upwards (as most all lids do) - I took a long bolt, drilled a hole in a 2x4 - put the bolt through the lid and the 2x4, put nut on, and tightened it down as the lid got bent until it was flat - saved another 3/4 in spacing, and it fits fine without even touching the underhood insulation. Has worked great for me for 2 years now. And the Spectre filter that it comes with is rechargable/cleanable just like a K&N.
Old Feb 17, 2011 | 01:12 PM
Kevman's Avatar
Engine: 2004 LQ4
A local supplier told me he has a bunch of spun aluminum ones I can try, each one having a 2" drop.
Old Feb 17, 2011 | 01:32 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have no such 'spacer ring' on my drop base. Do you recall the brand?
JamesC
Old Feb 17, 2011 | 03:02 PM
Car: 1992 RS
Engine: Carbed 350
JamesC
No - think it was Mr. Gasket cleaner base and I know it was a Mr. Gasket spacer. I needed it to clear the linkage/electric choke on my carb. I tried several brands of bases, all same issue - had to have the 1/2 plastic spacer between carb and cleaner base to clear carb linkage/choke. And it always broke from the heat, never made a good seal even when it wasn't broke, and the base always rubbed the dist right on a wire boot. That's why the 9in Spectre - it's been really nice.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
