rough running only in gear
Old Feb 17, 2011 | 06:48 AM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
I have an 87 iroc its a green elephant. It has a 327 block 305/350 intake quadrajet carbon and 305 heads. The car starts and isles very smooth, put it in gear and it shakes. When driving under load it sounds like its missing, it shakes the entire car..any idea's
Old Feb 17, 2011 | 08:15 AM
toomany's Avatar
Re: rough running only in gear
Sounds like it could be a vacuum leak. Start the car and spray some carb cleaner around all the vacuum hoses, intake gaskets, and carb base gasket. If the idle changes....you've found the leak. It might help to put the car in gear while you do this, of course you will need someone to hold the brakes for you.
If that checks out, I'd start with the basic tune up stuff. Filers, plugs, wires, timing.
customblackbird
Aug 15, 2021 10:16 PM
mizz0313
Aug 12, 2015 06:45 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
