Guide Plates
Car: '88 Formula
Axle/Gears: Stock
Guide Plates
guys I have 083 Heads that a real cool forum member hooked me up with, but they have guide plates on them. They are going on a 1988 350TPI center bolt engine. Can I drop them on or do I need to remove guide plates which would result in needing to mess with the studs and everything...
Car: '88 Formula
Axle/Gears: Stock
Re: Guide Plates
Thats the intention I just have no clue what length or how to figure it out? The car is an 88TPI so should be hydra roller?
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Guide Plates
Hydraulic roller cam
you should be fine with 7.200 length I have a set of hardened pushrods that length never used....they are one-piece design sell at a good price.pm me if needed.do you have 1.6 rockers I have a set also
monte87cortez
Sep 26, 2015 08:10 PM
