Bowtie phase 2 heads
Old Feb 20, 2011 | 09:17 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
About a year ago I bought a car with a 1979 4 bolt main GM 350 bored 30 over. I would like to get between 350 and 400 usable HP and decent TQ. I am looking at max HP around 5500-6000 RPM if possible. My cam specs are.
Cam Style
Mechanical flat tappet
Basic Operating RPM Range
2,000-6,000
Intake Duration at 050 inch Lift
236
Exhaust Duration at 050 inch Lift
236
236 int./236 exh.
Advertised Intake Duration
282
Advertised Exhaust Duration
282
Advertised Duration
282 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio
0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio
0.500 in.
0.495 int./0.495 exh.
I am running an edelbrock RPM manifold and 600cfrm carb with an MSD distributor and coil. The manifold and carb I can change out but I would like to keep the cam. The valve train is rebuilt 882 heads with comp cams roller rockers 1.5 and 600 lift springs. I have a chance on a set of GM phase 2 bowtie heads for a good price they are 184cc 2.02/1.60 65cc chambers do you think they will be what I am looking for?
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
