416 Heads ported "Is it Possible?"
Old Feb 22, 2011 | 07:57 PM
Dave23's Avatar
I ported a set of 416 heads. Had them flowed at a local shop. I think it may be wrong. I have ported a lot of heads but have never flowed any. Studied porting for 8 years but still never flowed any. Here are the numbers they showed.
lift in/ex
.100- 71/53
.200- 133/96
.300- 178/121
.400- 213/159
.500- 243/180
.550- 249/191
.600- 258/194
That don't seem possible. Those are really high numbers. They had tubes bolted to them. Would that make a difference? I am looking for advice, is this even possible. I want to find another place to flow them. I have full race 2.02/1.625 valves with unshrouded polished chambers. I did everything I have ever read (from all the pro in the world) to them. But, still that don't seem possible. What do you think? Thanks to all in advance.
Old Feb 23, 2011 | 06:52 AM
Re: 416 Heads ported "Is it Possible?"
That looks BEYOND outrageous.
I'd be expecting to see numbers in the low-mid 230s.
This sort of thing is like dyno numbers: the ABSOLUTE reading you get is almost irrelevant, what matters is HOW MUCH WHAT YOU DID CHANGED THEM. So I'd be expecting that had they flowed those same heads on the same bench with the same setup the same the same the same BEFORE porting and then again AFTER, they would have got the usual 20% or thereabouts of change, instead of 35% from known stock numbers to ... that.
LT1Formula
20
Nov 14, 2015 12:02 AM
italiano67
Aug 31, 2015 06:04 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
