new engine in, now what
Old Feb 22, 2011 | 08:59 PM
tjtaylor's Avatar
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
soo i just finished building my first motor, a 1973 sbc 400 . 60 over to a 410. i put it in a 91 camaro rs. now i need to know what to do now. i got it running and broke the cam in but had to shut it off quickly cuz the rockers started coming loose. i need to know the procedure for this action of tighting them down again and any other steps i should take to do to the motor. anything will be appreciated thanks
Old Feb 22, 2011 | 09:39 PM
4RCEPWRD's Avatar
Car: 82Z28
Re: new engine in, now what
I'm assuming your talking about valve adjustment and setting the lash...correct me if I'm wrong. Here's a good read for the process
http://shbox.com/1/4th_gen_tech2.html#adjust_valves
Old Feb 23, 2011 | 05:58 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I adjusted the first 8 at #1 TDC, and the other 8 at #6 TDC, they actually didn't make a sound..
Do you have the rockers with the locks, or no?
Old Feb 23, 2011 | 08:02 AM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
i have full roller harland sharp rockers that have the black nuts with set screws in the middle? idk if thats what your talking about and id rather do the adjustment while running not when its off. to hard to turn now with motor all hooked up, so if you have instructions for that thatd be helpful
Old Feb 23, 2011 | 09:25 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
What size cam
Screw in or press in studs, could be a source of the sound youre hearing
Old Feb 23, 2011 | 08:03 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
screw in studs and cam is .504 .525 lift .234 duration
Old Feb 23, 2011 | 08:24 PM
Axle/Gears: 4.11
Make sure they are torqued (50 lbs outghta do it) Then recheck adj. Make sure rollers are in good shape on the rocker arms, rocker body etc isnt hitting the retainer, etc, little stuff. Check for broken springs (far fetched but you never know). Youll find it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
