Intake manifold question
Old Feb 22, 2011 | 11:47 PM
davesengineshop's Avatar
Car: 1983 Z-28
Engine: 454
Transmission: TH700R4
Axle/Gears: 7.5" with 3.23 gears
Having trouble deciding which intake manifold to ues for my camaro. I have an edelbrock Performer and a Weiand Xcelerator. This primarily a strip car, so drive ability is not an issue. The car has a 400 small block, With an edelbrock performer cam, Rather small 1.84"/1.50" valves (for a 400) 58cc heads and they are pocket ported. I will be using a edelbrock 1405 carb. I plan to run the nitrous cheater set up I just aquired and they recomend a single plane, but i only plan on using the nitrous for grudge matches. so my delima is do I use the single plane (x celerator) or would the performer make more power, and i could just take it easy on the Nitrous. I plan to dyno test it when I finish it, however i will only have time to test one set up before racing season starts. So what do you folks think????
Old Feb 23, 2011 | 01:03 AM
4RCEPWRD's Avatar
Car: 82Z28
Re: Intake manifold question
I'd always heard to go single plane if spraying, and since this is primarily a strip car I would think go with the single plane as the car will live in the higher RPM range as well. However, out of curiosity I did some searching around and found an article on spraying a dual plane vs single and the differences seem to be negligible:
http://www.hotrod.com/techarticles/e...ing/index.html
Old Feb 23, 2011 | 09:10 AM
Car: 1983 Z-28
Engine: 454
Very good information thank you
Old Feb 23, 2011 | 09:25 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
with the heads and cam you are running, Id stick with the performer intake.
Old Feb 23, 2011 | 11:41 AM
Right, stick with the Performer... with those other things, what intake you run won't really matter; it's not the bottleneck, regardless. All you can do is make it worse by putting too big of one on it, which the Xcelerator DEFINITELY would be. A total mismatch.
Old Feb 23, 2011 | 11:45 PM
Car: 1983 Z-28
Engine: 454
thanks guys, i figured that would be the way to go, just wanted to get some opinions
Old Oct 28, 2019 | 10:14 PM
sack23's Avatar
Car: Iroc-Z
Engine: TPI 305
Heads $325 + shipping
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
