???'s 84 Berlinetta fuel/wierd noise
Old Feb 23, 2011 | 08:39 PM
JJs84Berlinetta's Avatar
well i filled up a week ago and only drive to work 26 miles round trip well gas gauge showed empty today cheked trip meter i had 60 miles since fill up what could be causing such crappy fuel milage? Next have this noise fron drivers side sounds like a heat shield lose but checked all good and can only here at acceleration from stop to about 2400 rpms then cant hear it anymore.
Old Feb 24, 2011 | 01:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: ???'s 84 Berlinetta fuel/wierd noise
Could be a bad fuel guage or sender issues. I'd fill it up all the way and see where the guage reads, reset odometer, grab a full 2 gallon can of gas and put in trunk, then drive 200 miles - if the car didn't run out of gas by then, then your mileage should be OK (better than you thought at least).
15 gallons (a fill up) times 15 mpg (you should get better mileage, but trying to keep you from running out on the side of the road) = 225 miles, so rounded down to 200 for added measure.
Lbibb
May 5, 2016 12:00 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Linson
Oct 1, 2015 09:50 PM
sjorgens
Oct 1, 2015 07:54 PM
rusty vango
Sep 29, 2015 02:44 PM
