rolled cam?
Old Feb 24, 2011 | 12:42 PM
crowbarmaster's Avatar
Car: 1982 Camaro Berlinetta
Engine: 327 with holley 4bbl
Transmission: T-5 WC
Axle/Gears: 3.42 non-posi
rolled cam?
http://www.youtube.com/watch?v=_XmRDc7mLSY
I am not sure what this is, first experience with this. one rocker doesn't move at all and one moves only but a quarter stroke. Any ideas?
Old Feb 24, 2011 | 12:45 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: rolled cam?
If all your pushrods are strait and the rockers aren't over-tightened, you killed the cam. Your lifters probably took a crap and caused it.
Old Feb 24, 2011 | 12:47 PM
Re: rolled cam?
so im looking at a new cam and lifters then? can I upgrade to a roller cam easily?
Old Feb 24, 2011 | 12:51 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Re: rolled cam?
They make special lifters that will allow you to run a roller cam. I don't remember what they are called though and they are about $500 for a set.
Only way to tell what is wrong is to pull the intake manifold, check your rods and lifters. If the rods are strait than you gotta examine your lifters and check for ovaling/nicks/damage. I'm sure the lifters aren't looking very healthy if the rods are still good.
Improper break-in and lubrication are the number one causes for cam lobes to flatten on a rebuilt motor.
Jorlain
Oct 8, 2015 01:57 AM
Lanz06
Sep 14, 2015 07:16 PM
TrevinE
Sep 14, 2015 03:20 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Strick1
Sep 4, 2015 07:11 AM
