can a intake manifold warp/crack??
Old Feb 24, 2011 | 07:23 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Transmission: 700r4 auto
Axle/Gears: ??????
I was reading in another thread, that intake manifolds were usually the cause of coolant in oil. I'm asking because my last motor had this problem and I'm planning on using the same intake manifold (edelbrock performer air gap) in my new build. Although my block was cracked in three places......I still wanna be sure its good (the intake). Can I check it myself? Or take it to machine shop? Thank-you
Old Feb 24, 2011 | 10:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: can a intake manifold warp/crack??
I don't know about your case, but my OEM TPI base warped. I wasn't getting coolant in my oil, but the engine was sucking oil into the combustion chamber. There was a TSB issued for this problem.
Old Feb 25, 2011 | 03:14 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
I would have the machine shop check it before you install it. My OEM TPI manifold had erroded away by the rear driver side coolant ports. I had them weld it and then grind it back down flat.
Old Feb 25, 2011 | 03:56 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Cant magnaflux aluminum, if its cracked youll be able to see it unless it was internal somwhere (doubtful)
Old Feb 25, 2011 | 09:11 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
A cracked manifold or int. ma. gasket produces vacuum at the oil dipstick tube. You can hear and feel it.
Denis V.
Old Feb 25, 2011 | 05:28 PM
K88-79's Avatar
Car: 88 iroc z28
Engine: Sbc 350
Axle/Gears: ??????
Thanks guys
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
