Short block / Long block difference
Old Feb 25, 2011 | 07:43 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
Any one could clarify me the exact difference between short & long block?.
I can't understand yet, because in my country only the term "block" is used for the main engine part with the cylinder holes.
Then, for me a "short block" is a block with 2 to 6 cylinders, and a "long block" could be a block more longer: from 8 to 12 or more cylinders.
Thanks,
Denis V.
Old Feb 25, 2011 | 07:48 AM
Re: Short block / Long block difference
It's a matter of what all is assembled onto the "block".
Block = big casting with cylinders in it
Short block = block, plus crankshaft, rods, pistons, bearings, rings, assembled
Long block = short block, plus heads, plus usually cam, timing parts, lifters, valve train, assembled; may or may not include tin; no hard-and-fast definition for exactly what is and is not included, beyond heads
Not a question of "length"
Old Feb 25, 2011 | 07:52 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
best answer!!!!!!!!!!!!!!!
Old Feb 25, 2011 | 08:52 AM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
sofakingdom is right.
Old Feb 25, 2011 | 09:02 AM
Denis.V's Avatar
Axle/Gears: No idea
Oohh, very clear. Thanks
This is because english language is more efficient and short than spanish.
In spanish you must says every word. For instance, if I need buy a short block, I must ask in the store: Do you have a block with cranckshaft, pistons, rings, etc, etc?
Seller will reply (I know): Oh, no, we only have the cranckshaft.
Then, I'll go to the second store and the same question again: Do you have a block with...etc, etc?. Then, the seller will say: Oh, no, we only deal with pistons.
It will be a long history for a short block. Never says about buying a long block here.
Finally problem will be solved with a block imported from USA (very easy. With the free trade agreement Chile/USA items pay 0% import tax).
For this reason, I must know what a short or long block exactly is.
Thanks very much again,
Denis V.
Street Lethal
Apr 30, 2019 12:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
MoJoe
Sep 24, 2015 09:12 PM
TheExaminer
Aug 26, 2015 04:59 PM
