305 torque specs???
Old Feb 27, 2011 | 06:09 AM
92RS_T-Top's Avatar
Car: 92 T-Top RS Camaro
Engine: 305 .30 over Mild RV Cam
Transmission: Auto 700R4
305 torque specs???
Can anyone tell me the torque specks for the fallowing parts?
1990 305 block (made in canada)
Aluminum after market intake (patern and torque specks)
Flywheel (pattern and torque specks)
Basicly I'm sticking in my newly rebuilt 305 I got while I'm rebuilding my factory 305 into a stroker motor and lost my camaro book in my resent move, motors ready to drop in but I forgot the torque down specks and pattern to bolt everything down to.
Thanks for the help.
Old Feb 27, 2011 | 08:40 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 305 torque specks???
Intake torque to heads: 35 ft.lbs.
Runners to either intake or plenum: 18 ft. lbs.
File Type: pdf
Old Feb 27, 2011 | 08:44 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Flywheel torque to crank: 60 ft.lbs.
You will be o.k. if you use a star pattern (this will always work if you're not sure).
AussiePr0nCar
Mar 6, 2020 04:04 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
