92 Z28 High Idle
Old Mar 3, 2011 | 10:24 PM
codster21's Avatar
92 Z28 High Idle
Ok so I have had my camaro for almost a year, never had any issues, only after market parts is an exhaust. About a month ago it started Idling high, like 2500, and since then the trans shifts in like 6-6500 rpms.
I swapped the TPS and The IAC off of an 88 that runs perfect, same issue, rejected timing, completely cleaned out the throttle body, I have used 2 cans of carb cleaner, no vaccum leaks. Can anybody help please.
thank you
Old Mar 4, 2011 | 07:59 AM
88gunmetalgta's Avatar
Re: 92 Z28 High Idle
Need a little more info, I'm guessing you have a tpi car.
only thing I can think of is that the throttle cable/tv cable bracket was bent or knocked around somehow. Since the TV cable is the only thing really controlling shift points, that would explain two normally unrelated problems.
Old Mar 4, 2011 | 08:43 AM
codster21's Avatar
Yes it is tpi. A friend told to disconnect the tv cable and see if the idle changges, nothing.
Here is something I though of last night, when it is idling the motor sounds fine, it doesnt sound like its over reving, what controld the tach?is it a cable or electric. I was wondering if it could have got out of wacked some how and is now reading higher?
Old Mar 4, 2011 | 01:59 PM
I would try a known good tach. Cuz if your car was actually shifting at 6500 rpm, it would be just screaming. At what mph does it shift?
Old Mar 4, 2011 | 07:37 PM
codster21's Avatar
it shifts out of first at about 15, then to 3rd at25, and final at 45, that is if you just barely push it,
if you punch it, it goes to the end of the red line and then will shift, sometimes right away sometimes it takes a sec, and yes it screams when its that high, I am goin to change the filter and fliud but I dont know if the tranny is affecting the idle, she has about 230k on her
Old Mar 4, 2011 | 09:06 PM
Sounds like the TV cable is about where it should be then. Transmission shouldn't affect the idle speed I dont think.
Old Mar 4, 2011 | 09:37 PM
codster21's Avatar
I didnt think so either,
any ideas?lol
I am so lost onthis one now
jklein337
Sep 19, 2018 06:23 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Dialed_In
Aug 20, 2015 01:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
