92 Camaro V6, will only start using starter fluid
Car: 1992 Chevrolet Camaro RS
Engine: 3.1L V6
Got a 92 camaro with the 3.1 v6 started acting up now it will on start using starter fluid, but once its started after spraying it, it will run till you shut it off, then you have to spray her again. Advice??
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
Re: 92 Camaro V6, will only start using starter fluid
Check the fuel pump and relay.
Car: 1992 RS
Engine: Carbed 350
There is a double fuel pump circuit system...
1) ECM sends priming signal to fuel pump relay, pump primes for 2 seconds to feed injectors fuel to startup, and then ECM runs fuel pump after startup
2) Oil Pressure Switch runs pump when it senses oil pressure
Your car isn't getting primed, so issue with your fuel pump relay.
After you start the car with starter fluid, then you have oil pressure, so the secondary circuit kicks in and runs your pump.
If like you say the car continues to run after starting it with starter fluid, then your pump is fine (it's working since the car keeps running), so it's your fuel pump relay that is the problem.
Car: 89 iroc z t top
Engine: 327f/t 0.060 489 cam high rise 750
Transmission: 700r4 auto 4 speed b and m shifter
Axle/Gears: 343 possi
do u have a distributor or coil packs
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
