cruse control confution
Old Mar 7, 2011 | 10:48 PM
Bipolar_Bird's Avatar
Transmission: 700r4e
I have a 91 firebird tbi, it has a cruse control box and is hooked up to the tbi but I have looked everywere for the controls inside the car and they are no were to be found(only so many placces for it to be). As far as I know it on the steering weele or on the blinker type switch? Is it aftermarket fromlast owner and never finished...? All I can say is WTF.
Any help would be great...
Old Mar 8, 2011 | 09:58 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: cruse control confution
Maybe a previous owner had a turn signal issue and replaced the turn signal lever with one that doesn't have cruise.
The switches were on the turn signal.
There's also a cruise control module in pass kick panel (pass floor board) behind the ECM module.
Maybe get us a pic or 2 of what you're looking at under the hood.
Old Mar 8, 2011 | 10:14 AM
that maybe the case. cuz i cant turn the brights on or of too???
Old Mar 8, 2011 | 11:43 AM
Car: 1992 RS
Engine: Carbed 350
The hi/lo beam switch is under the steering column, just above the brake pedal. You can see a rod that moves when you pull the turn signal lever - that rod runs to the switch and turns it on/off. Sometimes the rod just needs adjusted - loosen the two screws and push it up along the column just a tad - make sure tilt steering wheel is in driving position before hand (not all the way up).
tmellott89
Oct 14, 2015 02:06 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
tattmann
Sep 27, 2015 05:20 PM
Damon
Sep 26, 2015 04:29 PM
