No spark, totally stumped.
Old Mar 8, 2011 | 08:22 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Really Hope someone can help me with this as i am stumped. I have an 87 Trans Am 350 TPI.
I currently have no spark coming from the remote Accel ignition coil.
It has a new distributor and i am getting 12V from the pink wire in the gray connector.
When i check the terminals on coil i am reading no voltage with key in the on position. When i take the wires off the coil i am reading 12V.
So it seems that there is power in the wire but when it is hooked to the coil i read 0V.
It is a digital voltmeter if that helps any.
Does anyone have an ideas?
Old Mar 8, 2011 | 09:03 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Re: No spark, totally stumped.
anybody?
Old Mar 9, 2011 | 12:49 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Try testing power with a test light. Voltmemeters, because of their high input impedance, will show voltage even when there is high resistance in the circuit. If the test light doesn't light, check connections at the ignition switch and wiring between. You may have a bad coil. I don't put much faith in accel ignition products. Use your voltmeter to test primary coil resistance. It should be .5-1 ohm. Unplug the black connector from the coil and reconnect the gray connector. Use the test light to check for pulse on the white wire while cranking the engine. If you have a good pulse on this wire and no spark, replace the coil.
Old Mar 9, 2011 | 03:07 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Coil tested ok. I used a test light and confirmed power with ignition turned to on. I do not however have a pulse at the white wire which is the one paired with the pink one.
What you are saying is that i should have power to pink and the white should pulse when cranking correct?
I have power to pink but no pulse on white when cranking.
What could cause this?
Old Mar 9, 2011 | 05:18 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The distributor produces this pulse. The pole piece, timing core, pick up coil, and ignition module comprise the primary ignition circuit. You say the dist is new? What brand? BTW, I was tired and being creative when I said to disconnect the black connector from the coil and test for pulse this way. Ive never done it that way. Just thought it would be a neat method. The dist gets its power from the small pink wire that is in the black connector. So, you have to have both connectors installed on the coil to test for pulse. If you get no pulse this way, try disconnecting the tach circuit. The tach circuit is fed from the white wire of the gray connector. There will be an inline connector somewhere between the coil and the main engine harness. The tach can be shorted and pull down the referrence pulse to the coil.
If still no pulse, recheck all connections at the dist. If no problem found, replace the dist. There are a few brands of replacement distributors available. To my knowledge, AC Delco doesn't offer a complete unit. A1 Cardone is junk. Ill admit that Ive installed a few of their distrbutors in customers' cars and had more come back than what I consider acceptable. Two options are MSD or ACCEL. Both offer performance upgrades that are direct replacements for the OE unit. I have mixed feelings about ACCEL products. I installed the ACCEL 300+ ignition controller and Billettech distributor. The module left me after a few years. The distributor is still going strong with my new MSD Digital 6. MSD makes the Pro Billet replacement.
Old Mar 10, 2011 | 10:46 AM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Should the primary ignition coil be giving off spark with only the grey connector in and the black connector that goes back to the dist disconnected?
Old Mar 10, 2011 | 11:05 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
No. There should be no spark with the black connector disconnected. What do you mean by primary ignition coil? There is the pick up coil in the distributor, and the ignition coil. We sometimes refer to the pick up coil as the primary ignition coil. The ignition module contains an amplifier which converts the sine wave produced by the pick up coil, as the pole piece and timing core pass each other, into a digital crank referrence signal for the ECM. It also, amplifies this signal to charge and discharge the ignition coil. The ignition module receives its power through the small pink wire that is in the black connector.
Old Mar 10, 2011 | 11:08 AM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
I meant the ignition coil not the pickup coil. Is it possible to test without the ECM to rule that out?
Old Mar 10, 2011 | 11:33 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
As I remember, you should be able to generate spark from the distributor with the 4 wire connector of the ignition module disconnected. this isolates the distributor from the ECM.
Old Mar 10, 2011 | 01:59 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Well i checked power on the black connector coming back to the distributor and it shows the test light is showing power on both wires in that connector. Is this the way it should be? Do i have a bad connector?
Also when i ground the negative side that goes to the ignition coil it then only shows power on the pink wire in the black connector.
Old Mar 10, 2011 | 02:28 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
That's normal. With the key on engine off, your seeing ignition power feeding back through the coil primary. Do you have a service manual? the factory (HELMs Publishing) manual has a very thorough diagnostic flow chart for no spark. Did you try it without the 4 pin connector plugged in? Have you verified that the distributor shaft is turning with the crank?
Go back over the tests I've described and make sure you've done them all. Have you tested for spark on more than one wire? the coil primary can be shorted, causing no spark and pullin down the PIP(primary ignition pulse). Disconnect both connectors from the coil. Use a test lead to route power from the pink wire in the gray connector to the pink wire in the black connector. Be sure that the lead doesn't touch the white wire. With the distributor connected this way, test for PIP while cranking engine.
If no PIP, double check test. Check grounding of distributor and ign module. If all checks good, remove module and have tested. If module tests good, use an ohmmeter to check pick up coil. It should read between 800 and 1000 ohms, if not replace distributor. If you just bought the distributor new, skip the last 2 steps and return the distributor for exchange.
Old Mar 10, 2011 | 03:12 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Success! Thank you for all your help. Looks like the connector going back to the dist was loose. Plugged it back in and now getting spark.
Old Mar 11, 2011 | 05:45 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
See? You made me do all that typing for nothing. You know how bad I suck at typin? My index fingers are getting raw. LOL. So glad it was something simple. Happy motoring!
Old Mar 26, 2011 | 03:08 PM
slaman37's Avatar
Car: Current project is 70 Monte Carlo
Engine: 350 TPI (SD)
Transmission: 200-4R
Axle/Gears: 3:73, 12 bolt Limited Slip
You didn't type all that for nothing because I am having the same problem and this is just the info I needed. Heading out to the garage to give it a try.
Old Mar 28, 2011 | 07:08 AM
slaman37's Avatar
Found it. turns out a couple of pins got bent down on the ignition module in the distributor when I first hooked them up. Got fire, now just have to get the gas leak on the fuel rail and the VATS issue fixed again.
Old Jun 24, 2012 | 12:59 PM
wildstang3's Avatar
The small two prong grey plug that has key on power where does that go? I have been searching for two days and cant find where it plugs into Thanks Tyler
Old Apr 15, 2013 | 09:08 PM
Jcgta's Avatar
Same problem kinda. No spark. I have replaced ignition control module mass air flow checked fuses
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
