85 trans am running poorly
Old Mar 11, 2011 | 05:50 PM
nate85ta85's Avatar
Car: 85 Trans Am
Engine: 355ci
Okay I just bought an 85 ta for 1500. The engine is all chromed out and painted and the body is in decent shape. So I couldn't say no. It's running slow for the components it has and i'm trying to figure out where to start. Any ideas are appreciated. Here is what is in it.
85 Trans Am T-top, Chevy 355 4 bolt ,manual 5 speed trans
350 High Nickle 4 bolt main Small block Chevy Bored .30 over(355),
Edlebrock Performer EPS Aluminum Intake
Headers
Edlebrock 600 carb
Port Job job on heads. the crappy 462624 set, i didn't know this until i took the valve cover off yesterday...
Comp Cams Roller Rockers with 1.52 lift
A 280-H Comp Street Cam ,
Centerforce clutch ,
CS-144 140a Alternator,
3.73 Gears.
crappy exhaust
have not done timing and carb tune yet
the first thing i did was an oil change, and i only drained about 1 qt... i'm really hoping there isn't major damage done to it because of lack of maintenance...
my rsx beat it in a 3rd gear pull no problem... i'm guessing the best place to start is the cylinder head, if so what do you guys recommend
camaro11j
Sep 19, 2018 08:49 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
3rdgenparts
Aug 6, 2015 09:03 AM
