Lookin for a cam!
Car: 1989 iroc camaro
Engine: 5.7
Transmission: the auto 700r4
Lookin for a cam!
im looking to put a new cam in my 1989 Irco (5.7)
the way its going to be set up,took the tpi setup off and putting headers,3port regulator,performer manifold etc...
so pretty much everything is stock in the engine and id like to know what is a good cam for this setup would be and what some are running?
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Lookin for a cam!
It's really subjective. Would like to know why you replaced the TPI with a carb through. That's sort of going backwards. Would also be good to know exactly what else has already been done to it. I'm assuming you don't need an emissions inspection?
