Egr Temperature Sensor
Old Mar 14, 2011 | 10:21 AM
Deven534's Avatar
Car: 1987 Pontiac Trans Am
Engine: 5.7 350 Tpi V8
Need an egr temperature sensor for my 1987 pontiac trans am with a 350 tpi V8 in it...can anyone help me out?
Old Mar 14, 2011 | 11:51 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Egr Temperature Sensor
There's no "temperature sensor" in the EGR system, so I'm lost as to what you're looking for. Autozone/Advance/Oreilly/RockAuto all sell everything EGR associated.
Old Mar 14, 2011 | 12:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, there is a temp sensor in the EGR valve for TPI.
Just go to the parts store and buy one.
Old Mar 14, 2011 | 12:57 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
the part is discontinued, find it on bay for about $80 dollars. see "EGR temp sensor has been discontinued"
https://www.thirdgen.org/forums/tpi/...ensor-has.html
Old Mar 14, 2011 | 02:12 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
PM me, i have a good used one I'll work out with you, Cheap.
Attached Thumbnails Egr Temperature Sensor-012.jpg   Egr Temperature Sensor-013.jpg
Old Mar 14, 2011 | 03:10 PM
Car: 1992 RS
Engine: Carbed 350
Oh wow - never knew that. Sorry I was wrong!
Old Mar 14, 2011 | 04:04 PM
red rock's Avatar
Car: 1987 iroc
That's what's great about these third gens, you learn something everyday?
Old Mar 14, 2011 | 05:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Now $12.60
Someone on another Forum just ordered one
http://www.theautopartsshop.com/Sear...nd+PartDetails
Old Mar 14, 2011 | 11:40 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
IIRC, the MAF cars had a temp sensor and the SD cars don't. So might be why camaronewbie thought there wasn't a temp sensor. I don't ever recall seeing anything on my car that looks remotely close to what is pictured above. Please correct me if I am wrong.
Old Mar 15, 2011 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The SD cars register the change in manifold vac through the MAP sensor to determine if EGR gases are flowing when commanded
Old Mar 15, 2011 | 10:08 AM
Deven534's Avatar
Old Mar 15, 2011 | 10:09 AM
Deven534's Avatar
i just sent u a PM
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
