just installed new brakes. now i smell burning brakes.
Old Mar 14, 2011 | 04:50 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
So i just installed new rear rotors and pads on my 89 gta. everything when good. so i went driving to break them in but after that i notice my car does not coast at all. from 40mph my car slows down rather quick. I hope i don't have a frozen caliper? i did this same brakejob 4 years ago and i had to replace my driver side rear caliper because that one was frozen on me. any idea. do they just need to be broken in more. i have been driving around for about 30 miles and still smell brakes.
Old Mar 14, 2011 | 05:31 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: just installed new brakes. now i smell burning brakes.
This needs to/will be moved to the brakes board. Take the wheels and pads off and see wh ich one is glazing. Should indicate which one is sticking. Also, if you don't coast, does the car pull to one side or the other on it's own (more than from the crown of the road)? Should give you an idea. Hard to diagnose brake wear over the internet. Did you also replace the rotors? take a look at your old pads, did one of them wear more than the others?
Old Mar 14, 2011 | 05:42 PM
Car: 91 formula
no the car does not pull to the side. yes i did replace rotors and pads. and no the old brakes are even on both wheels.
Old Mar 14, 2011 | 05:49 PM
torque_is_good's Avatar
you already know the answer; calipers
Old Mar 14, 2011 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps a flex line went bad in the exchange.
JamesC
Old Mar 15, 2011 | 03:59 PM
Car: 91 formula
some new info. I did stop my car at about 40 mph hard and the car does not swing to any side. I did feel both wheels and they car both very warm. if a caliper was seized would it swing to one side? im giving it a week and see if it get any better.
Old Mar 15, 2011 | 08:00 PM
it need only be "lazy" to keep the pads engaged and getting hot. Eventually, the pads will wear down enough that you'll have clearance and no more burning smell
now the more difficult question; what color are you going to paint the calipers or are they already painted?
Old Mar 16, 2011 | 06:15 PM
Car: 91 formula
just lifted the car off the ground. but it in N and the wheels are so hard to turn by hand.
Old Mar 16, 2011 | 06:26 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Your calipers are probably working still if it's not pulling when you gradually apply the brakes. Someone already said it though, one or both probably aren't retracting fully.
Old Mar 16, 2011 | 06:48 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
sounds like your calipers are both locked up
Old Mar 16, 2011 | 07:30 PM
yeah yeah, we all agree it's the calipers and the OP knows that as well; but what color is he going to paint them???
Old Mar 16, 2011 | 11:19 PM
Car: 91 formula
i most likley will keep them stock color. i just not a fan of painted calipers.
Old Mar 17, 2011 | 11:43 PM
Car: 91 formula
just want to let everyone know i found the problem. guide pins. they were toast so i ordered new ones and installed. im good to go.
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
