Will not pass smog
Old Mar 16, 2011 | 03:47 PM
mr2low's Avatar
Will not pass smog
i can anyone help me out i replace O2 repleace idle air control my cat good put the OBD and said all good but still fail what more can i replace run good it a 1990 camaro rs V8 305 can anyone help me out THANK YOUit all help replacing the part but numbers where still to high for me to pass
Old Mar 16, 2011 | 04:06 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Will not pass smog
where do you live?
Old Mar 16, 2011 | 04:21 PM
mr2low's Avatar
calif
Old Mar 16, 2011 | 04:29 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Need to know more about the car. Have you done anything to it? Original engine? Modified it in any way? Failing just the smog or the visual too?
Old Mar 16, 2011 | 06:14 PM
mr2low's Avatar
all stock it pass the visual original motor
Old Mar 16, 2011 | 08:11 PM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Try running denatured alcohol. get your tank real low and pour about a gallon of ethyl based alcohol in there. Aim for a 1:4 alcohol to gas ratio or higher. Have some gas in your trunk and when you drive away dilute it asap. the alcohol will be hard on your engine.
No guarantees it'll work. Do your research for your specific engine and fuel delivery system. I'm from MI, so I have no idea if it's legal or not. Good luck.
SMOG testing is BS IMHO, though. My feeling is this is a free country and you can emit as much smog as you d*** well please.
Old Mar 16, 2011 | 08:17 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
if your car is in good tune.....go to your local parts store and buy an emission additive.......before you test... DRIVE THE CAR AT LEAST 1/2 HOUR AND DON'T SHUT THE CAR OFF...GOOD LUCK
Old Mar 17, 2011 | 12:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Make sure the engine is nice and hot too.
Old Mar 17, 2011 | 01:08 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
I ran into this with my truck. Block off the radiator with a piece of cardboard. and with about 6 gallons in the tank of gas i put two pints of alcohol in the tank. Drove it for a bit then I held it at about 2500-3k rpms 30 seconds before the test to get it hot and it passed with flying colors. and when i failed before hand I was close to being a gross polluter. Note* dont block off the whole radiatior with cardboard on a hot day.
Old Mar 17, 2011 | 01:09 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
How far out are you?
If it is close as others noted some alcohol might help (for the car but you could also try some for the tester...). Also make sure the engine is warm for the test.
As a side note, has anyone tried topping up with E85 for this purpose (obviously not a full tank!)?
Old Mar 18, 2011 | 01:12 PM
74Novaguy's Avatar
Axle/Gears: Stock
A gal of E85 to about 5 gals of lets say E10 or 12 since that what gas is now in cali and we cant get any pure stuff anymore. should work and proboly be cheaper than going to the drug store for denatured alcohal.
as far as other parts... Thermostat can cause tons of prolems. but cardbord in front of the radiator should fix this problem.
jaridjohn
Oct 5, 2015 07:01 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
