What is with all the valve covers with no oil filler...
Old Mar 17, 2011 | 12:54 PM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
Started looking for aftermarket (or stockish) steel valve covers for my 350 (70s vintage heads and block) and I am blown away that most of the aftermarket stuff has no oil filler hole! Most of the ones out there have only one hole per cover (PCV on one and vent on the other--both left and right covers are the same stamping). How are people getting oil into their engines these days using these covers, are they running pre 70s intakes with the oil filler on the intake, are they dripping oil into the dipstick...?
My guess is this is a cheap made in china thing where they are using the same stamping for both sides. I have notice the trend for the cast aluminum ones as well. I have even noticed it on the centre bolt covers!
I must say I am thoroughly puzzled by this.
Old Mar 17, 2011 | 01:42 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: What is with all the valve covers with no oil filler...
Pull out breather, add oil, replace breather.
Old Mar 17, 2011 | 07:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Shouldn't be
30+ years ago many US made covers came without the filler hole ( for those that want a cleaner look).
The hole and lugs for the filler cap were cast on the underside of cover but you had to cut the hole out if you wanted to use it
Old Mar 28, 2011 | 04:12 AM
1969RSSS's Avatar
Car: 69 Camaro,88 T/A,03 Prius
Transmission: M22
Axle/Gears: 12 bolt 3.73 posi
what he said, been doing it for years.
MoJoe
Sep 24, 2015 09:12 PM
Thaney9
Aug 29, 2015 03:16 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 01:18 AM
