SEND GOOD FUEL
Old Mar 20, 2011 | 10:32 PM
my_lil_fire's Avatar
Car: 87 formula 350
Engine: v8
Axle/Gears: aussie 9 bolt
SEND GOOD FUEL
On my 87 formula, i swapped the tpi for carb. everything is well but i have no clue what to do with the fuel pump in the tank. i have a manual pump on my block want to get rid of the pump in the tank. should i remove it and ad fuel hose or do they make a kit? any help would be great thanks
Old Mar 20, 2011 | 10:46 PM
dead sailor's Avatar
Car: 82 Z28
Engine: 355 solid roller (395 stroker soon)
Transmission: t-56
Axle/Gears: 9 bolt posi
Re: SEND GOOD FUEL
I would try to find a used sending unit from a car that did not have an in-tank pump. It will have the pick up that you want, and it should fit right in there. I'm not sure which years and models came with the sending unit that you want, but I do know that an 82 does.
Old Mar 20, 2011 | 10:59 PM
frankinmaro's Avatar
Car: 87 Frankinmaro
Engine: ZZ4 short block 67 327 462 castings
Transmission: TH350-c out of Y body
Axle/Gears: 97 4th gen Torsen 3.23
Re: SEND GOOD FUEL
I have a sending unit out of an 87 carbed V8 I would swap with ya.
Old Mar 21, 2011 | 11:11 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: SEND GOOD FUEL
1987 factory carbed car also had an intank pump - a helper pump if you will - might not help any or could be a benefit ... but if I was to trouble myself to drop the tank I might want to get rid of the electric pump altogether.
You can fab your own - just replace the fuel pump with a piece of 3/8 brake metal line and add the sock on the end.
BUT - the easiest thing to do is to use the in-tank pump (assuming it still works), use a Mallory 4309 regulator, and replace the mechanical pump with a blockoff plate.
Old Mar 21, 2011 | 11:14 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: SEND GOOD FUEL
I would personally use the intanke pump. You won't suffer from vapor lock like you can/will get from just running the manual pump on the engine block without the in-tank pusher pump. You just need a regulator to bring the pressure down to 6-6.5psi.
Old Mar 21, 2011 | 11:15 AM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: SEND GOOD FUEL
^I would do that, regulate the in tank pump down. You can't suck through the electric pump so you either have to remove it or use it. Dropping the tank on a 3rd gen is enough of a PITA I would just want to use the electric pump.
Old Mar 21, 2011 | 06:56 PM
Car: 87 formula 350
Engine: v8
Re: SEND GOOD FUEL
thank you for the advice
Old Mar 22, 2011 | 07:01 PM
Countryguy's Avatar
Car: 91 Camaro RS
Engine: 383 Stroker Built
Transmission: Turbo 350
Re: SEND GOOD FUEL
Why not use both?
Old Mar 22, 2011 | 07:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: SEND GOOD FUEL
Its a TPI pump, which puts out far more fuel pressure than a carb 'helper' pump or a TBI pump. I would take out the TPI pump and use either a basic pick-up setup, or the right helper pump.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
