cylinder head leak help
Old Mar 23, 2011 | 02:09 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I'm putting this engine together and before it goes in the car I want to make sure no coolant will get in this engine. I did a compression test and all the cylinders had around 160 psi, is this good enough to know that the head gasket has sealed correctly? I would try the leakdown test but I don't have an air compressor. Is there anything else I can do?
Old Mar 28, 2011 | 12:13 AM
1969RSSS's Avatar
Car: 69 Camaro,88 T/A,03 Prius
Transmission: M22
Axle/Gears: 12 bolt 3.73 posi
Re: cylinder head leak help
compression check is a good start but wont show leaks from small cracks that get expanded with heat or leaks past head bolt threads and such. The only other thing you could really do is install the intake/water pump and seal everything up and pressure check the cooling system side.
NinjaNife
Aug 23, 2015 11:49 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
