do firebirds require certain oil pan?
Old Mar 24, 2011 | 06:37 PM
DirtRyder85's Avatar
Car: 86 Firebird
Im about to drop my new motor (350) in and i started looking at the pan and realized the stock 350 pan from summit may hit the engine crossmember, so i took a look at the original 305 and its pan has what looks to be a designated wave formed in the pan for k member fitment. Do i need to use my stock 305 pan on this 350 or will the stock 350 pan fit? sorry searched everywhere couldnt find this exact answer. dont wanna go with the trial and error method as i may squash my brakeline across the k member
Old Mar 24, 2011 | 06:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: do firebirds require certain oil pan?
All 3rd gen oil pans are a tad different than most, because there has to be enough room in front of the pan for the exhaust (between the pan and the crossmember).
Old Mar 24, 2011 | 07:23 PM
Car: 86 Firebird
ah thats another thing i was concerned about. thank you! so my best bet is take off my 305 pan clean it up and put in on my 350? it should fit okay being that they are both one piece rear seals?
Old Mar 24, 2011 | 08:40 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
That would be fine.
I wish somebody had told me about the exhaust thing before I put in my 350, hooked everything else up, then went to put on the y pipe and the sump was in the way, leaving me to pull it all back out to put my original pan on.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
