distributor question
Old Mar 24, 2011 | 08:17 PM
danialreed's Avatar
I recently put an HEI distributor in my car due to swapping to a carb. The vehicle is at top dead center on cyl 1, and I got the rotor to point towards the number 1 cylinder. The problem is once I put the cap on it is between two plugs. In the pic attached the black mark next to the retaining hook (right of) is where the rotor is pointed. Any help would be appreciated.
Old Mar 24, 2011 | 09:31 PM
torque_is_good's Avatar
Re: distributor question
what do you mean "any help would be appreciated"?
my rotor is pointing at 3:30 for cylinder #1. As long as you know where #1 is you're all set
Old Mar 24, 2011 | 09:51 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
maybe advance ur timing?...a lil...
Old Mar 24, 2011 | 11:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yep - turn the base a little and the rotor will point where you want.
Did you get TDC #1 cylinder on compression stroke?
Old Mar 25, 2011 | 11:51 AM
danialreed's Avatar
Yes, i have tdc on cyl 1. I moved the base and redid it. It now points at just one plug on the cap. Thanks for everyones input.
Old Mar 25, 2011 | 03:05 PM
Car: 1992 RS
Engine: Carbed 350
Yes, i have tdc on cyl 1. .
You do know there are two "TDCs" right? #1 cylinder piston comes up for compression stroke, AND it comes up for exaust stroke.
I'm just double checking that you got TDC #1 on compression stroke - ie finger over #1 spark plug hole and felt outward air pressure.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
