Where is the gas going
Old Apr 2, 2011 | 10:00 AM
  #51
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
Re: Where is the gas going
Well I took the GTA out this morning for a long test drive and watched the needle on the fuel guage drop...Something is definately wrong. I will go to a heated O2 sensor as soon as it comes in. I do have a question though. I purchased an ECM awhile back as a spare. It is a factory authorized Delco re-manufactured 01227165 ECM. It has the blue memcal under the access cover so it hasn't been pilferaged. Would you guys recommend swaping this with the one in my GTA ?
Old Apr 2, 2011 | 11:35 PM
  #52
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The best advice I can give you is to connect a scan tool(must be GM OBD1, 12 pin ALDL) and look at Block Learn and Integrator for clues to out of whack fuel correction. As far as O2 sensor brands, Bosch is the original maker of EFI and the O2 sensor. I've never had a problem with their sensors on domestic applications. Denso makes the very best O2 sensor. NGK isn't bad.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
