Fuel pump keeps going bad
Old Mar 26, 2011 | 02:23 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Engine: 350 5.7L Carb'd
Axle/Gears: Disc 2.77
the dudes who owned my car before me converted it to carb, so its running off of an external low psi fuel pump, and it just went bad, again, this will be the fifth time ive had to replace it in two years
the intank pump has already been removed, so its not because its sucking through the old pump, there is no trash in the tank and the filters are still clean
someone told me that not having a return line or the pump not automatically shutting off once the bowl is full in the carb will burn the pump up eventually, i dont have a return line, its been clamped off and the line from the tank is just open, and my fuel pump never shuts off, it runs all the time as soon as i turn the key on
anybody have an idea of how i can fix this?
any help will be greatly appreciated
id love to just put the tpi back on, but im still waiting for a good deal to come along for everything i need to do it
Old Mar 27, 2011 | 12:48 AM
1969RSSS's Avatar
Car: 69 Camaro,88 T/A,03 Prius
Transmission: M22
Axle/Gears: 12 bolt 3.73 posi
Re: Fuel pump keeps going bad
I would check the voltage drop at the pump and check the Resistance of the ground wire to body ground (less then 1 ohm). You could add a fuel regulator with a return port but i don't think thats the problem unless your buying super cheap fuel pumps.
Old Mar 27, 2011 | 01:02 AM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
thanks will do, i have been buying cheap pumps though, havent gone over 50 bucks for one
where can i get a good, cheapish pump to buy that will work for a long time? of course ill be adding a fuel regulator with return with it, so i can help prevent this from happening again in 3 months
Old Mar 27, 2011 | 03:09 AM
1969RSSS's Avatar
Transmission: M22
I would look at Summit or Jegs and buy their brand pump if your looking for semi cheap good pumps ( they usually buy good name brand stuff without the name brand name on it and sell it at a discount).
I would still check your power and ground as any pump will fail if it isn't right. You also stated that the old pump was removed, was the fuel sock also removed ? if so was a new one added or a filter installed between the tank and the new pump location ? if not you should add one as any trash at all from the tank will be running through the pump impellers.
Old Mar 27, 2011 | 01:50 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
thanks, ill check into that, and yes it has a filter before the pump
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
