Power steering lines
Car: 85 Z28
Engine: 327
I have a whole/crack in my power steering line. I think it is a high pressure rubber line slpiced in between two metal hard lines. What would be a good replacement line
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Power steering lines
If you can get it off, I would just take it to Napa or somewhere similar and have one fabbed IF you can't purchase another one from a parts house. Most of them should be available at your local parts house.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No need to fab up a custom hose. Just get an off the shelf replacement complete with steel lines and fittings on both ends. Available from any auto parts store.
And I am assuming you are looking at the pressure hose, not the return hose, since that is the one that usually lets go first. The return hose is easy to identify: it isn't crimped onto the lines, it's just attached with clamps. And replacing that one is easy - just use the correct length of neoprene hose.
Car: 85 Z28
Engine: 327
Ya. I don't know if this is how it is supposed to be, or if the PO hacked it in. I suppose I can take a pic and bring it into napa
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
if its the return line you wont be able to take the metal line off the power steering pump as its part of the pump itself.
Car: 85 Z28
Engine: 327
If it is return line, what would be good hose to patch in with. Would braided stainless work
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
i work at a napa and we sell special powersteering hose so actual power steering hose would be the best.
z
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
What is the actual size, not length of the return line? Some sources say that its 3/8"?
Just go to the parts store and order up the one for your car.
Not worth the effort of trying to cobble someting together.
Car: 1987 Camaro LT
I have a new stock high pressure line. That's installed and working fine. I just want to confirm if the return hose is a 3/8"
Car: 1987 Camaro LT
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
