belt jumping
Old Mar 30, 2011 | 12:03 AM
native1031's Avatar
belt jumping
84 H.O.
Ive noticed the belt attached to the alternator jumps and sorta squels when I rev it. Could this be a bad pulley?
Old Mar 31, 2011 | 03:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: belt jumping
Check the alignment with the other pulleys.
Old Apr 9, 2011 | 07:08 PM
native1031's Avatar
Re: belt jumping
Sorry for such a late reply, but theres been a lot of bad weather. I got to look at it today and it seems the alt. is pushed back a bit. I dont have the greatest eye, but seems like its on a slight angle compared to the rest.
I have no knowledge of adjusting belts and pulleys
Old Apr 10, 2011 | 09:31 AM
Re: belt jumping
Sounds like somebody hacked the smog pump off, and didn't bother noticing that the little bracket that held the diverter valve was behind that tubular spacer thing on the bottom alt bolt.
Pull out that bolt enough to be able to slip a washer in there to take up that space. Then tighten the belt correctly.
Old Apr 10, 2011 | 02:09 PM
native1031's Avatar
Re: belt jumping
The top of the alt is further back then the bottom of the alt.
Ill try and take a better look to see if anything was bent or if the bracket was hacked off like you said
RS Reaper
Oct 17, 2018 07:52 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
