Questions on rebuilding small block chevys
Car: 88 IROC-Z
Transmission: 700R4-currently being mildly built
Axle/Gears: stock 2.73:( with limited slip
I'm looking to rebuild(250-450hp when finished) a 350 (first engine rebuild) and had some questions:
With a tight budget, which would be better. EFI or carb?
What are the differences between the 350 generations in terms of the block?
Will any transmission, such as a T-5 bolt on to a 350?
How many job-specific tools will I need to put everything together?
Does anyone know of a oiling diagram for the 350?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Questions on rebuilding small block chevys
carb or efi - going to depend on your local laws and what year car you have - not legal to carb a factory efi motor in all states/counties
V8 differences - nothing externally with block from whenever they started making them until the LS1 motor - LT1 might have some internal differences
tranny - yes, if it's a V8 tranny
tools - just basics - rachet, sockets, screwdrivers, pliers, etc. etc. Might want a torque rachet, available at Harbor Freight cheap. Need a engine lift when transplant time comes.
Oiling? Like any other SBC - they are all the same
Car: 88 IROC-Z
I have all of the basics. I was mainly talking about things like valve spring compressors, cam bearing installers, etc
Car: 1990 Camaro wide body
Engine: 421 Dart SHP SBC
Axle/Gears: 3.73 Eaton
You will also need more tools if you re-doing the bottom end. You'll need a piston ring compressor and so on. As for spring compressors, it's on how much you want to spend you can buy assembled heads. Or even have a engine Machine shop rebuild the heads.
Car: 88 IROC-Z
http://www.summitracing.com/parts/BRO-1020000
http://www.summitracing.com/parts/BRO-1021000
Still debating assembled or bare. I think I can get a better deal assembling them myself, which adds experience too.
Just do the math for the compression ratio to make sure your running the right Combustion Chamber, an make sure your cam matches your max valve lift. Another note to think about is if your running headers. It's much nicer to have angle spark plugs then, straight.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Theres a lot of nuances in assembling heads. You'll need to know about installed spring heights and various clearances and spring pocket sizes and potentially shims and so on... Invest in a good book if you wanna go that route. Of course you should be investing in some good books anyway.
http://www.amazon.com/Rebuild-Small-...1539747&sr=8-3
http://www.amazon.com/How-Rebuild-Yo...ref=pd_sim_b_1
Some of the info in the second book is outdated but you'll learn enough to know what the right questions to ask here are. And what questions to ask the machine shop. The dvd that comes with the first one is incredibly helpful.
Just take performance tips with a grain of salt in these, because some of the info can be old or outdated. Performance is all the top end. Your intake, cylinder heads, and camshaft will determine how much power you make, and for a lot of up to date first hand experience with modern parts consult us here at TGO.
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
With a decent NEW shortblock so cheap $1190, it costs about the same as a rebuild.
pick your cam, heads, induction
http://sdparts.com/details/gm-factor...parts/12556121
or get a long block
there is no badge of honor for trying to install cam bearings or pressing in wrist pins
you'll be spending $$$ at the machine shop so either have them do it or get a long/short block
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Youre gonna want to have any used parts checked by a competent machine shop anyway. For a little extra $ you can hand them the parts, have them check them, then assemble the long or short block. LOT less headache and effort on your part. Thread Starter
Car: 88 IROC-Z
I can't afford 1200 for the block. I'm gonna get a junkyard block and have it cleaned, machined, and .030 bored. Everything else needed will be taken to the machine shop to press on.
Short block = a block with all that machine work done to it, all new parts, and the labor that built it
Long block = short block plus heads, maybe cam, maybe valve train, maybe oil pump, maybe tin, maybe even intake
I'll almost bet money that you can't buy a bare block, have it bored, honed, cleaned, checked, whatever ; buy parts; have the machine shop assemble the pistons & rods, press in cam bearings, etc.; and build it yourself from there, for less than $1000.
Which makes a $1200 BRAND-NEW assembly, with a GM warranty (therefore as close to risk-free as you're ever going to get), not such a bad deal.
Or conversely, if you can't "afford" that, (a separate matter from just wanting to do it some other way) you probably can't "afford" to build one, either.
Or conversely, if you can't "afford" that, (a separate matter from just wanting to do it some other way) you probably can't "afford" to build one, either. Thread Starter
Car: 88 IROC-Z
Or conversely, if you can't "afford" that, (a separate matter from just wanting to do it some other way) you probably can't "afford" to build one, either.Machining, cleaning, bored-$350
Crank, bearings, caps (Lunati sledgehammer) -$800
Rods (scat I-beams)-$450
Piston kit (SRP professional)-$580
So with that setup I'm at just over $2200. For the 500+ hp and 650+ on spray, thats a pretty good deal.I'm considering the Summit 383 stroker block,$700, but I'm not sure if it can hold up to 650hp. Anyone know?
And while I'm on it, why is there 1- and 2-piece rear main seals? Which are better?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You're missing the align bore you need to put new caps on.
There are 1 and 2 piece rear main seals because GM changed the blocks. Whichever is better depends on which block you have.
I plan on building everything myself. I checked and here are my prices(so far):
how did you go from 250HP-450HP (which is a huge difference by the way) and tight budget, couldn't afford a $1200 short block or 290HP $1999 long block into wanting to build a 650HP engine and thinking you can do that for $2200????????????????????????????
I'm very confused now
Oh, the heads alone are going to be $2200 minimum for a 650HP engine
good luck doing it with a small block that can be street driven
Car: 88 IROC-Z
Oh, and I said 500 normally, which can be street driven and cheap.
These are what I'm thinking.
http://www.jegs.com/i/Edelbrock/350/...0002/-1?CT=999
http://www.dartheads.com/products/cy...der-heads.html
not sure which ones yet, but leaning toward the Edelbrocks.
As for valve train,
http://cgi.ebay.com/ebaymotors/LUNAT...#ht_2932wt_947
or
http://cgi.ebay.com/ebaymotors/COMP-...#ht_3015wt_947
so yes, they are
I found a job
Do you mean assembled or bare heads?
As for valve train,
or
so yes, they are
As for valve train,
or
so yes, they are
Hypotheticals are nice and browsing Summit etc is also OK, but you really need to set you goal for the vehicle, not the engine.
And you make a statment now about 500HP NA street driven that's easy and cheap. I'm going to bow out at this time because "cheap" is a relative term based upon how much on hand cash you have to burn. I know for a fact that a 500HP streetable engine is not "cheap" to me, never mind what you must do to support the 500HP NA.
Car: 88 IROC-Z
And I can't go to the track. The closest one(gateway, 60 miles away) shut down last year.
BTW, sorry to argue so much, It's just my nature.
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
A T5 Won't hold that kind of HP for very long either.
What do you mean cute little games? Is there something wrong with all $1200 bare heads?
What do you mean goal for the car? I want it to be a low-mid 12sec. car that can be street driven and can corner moderately well. Basically a corvette in a third gen camaro with a 383.
well, according to hot rod, you can get 592hp for $2300 in a 4.6L
please understand something, it doesn't bother me in the slightest. My posting style on this and other auto forums is based from years of experience. You can choose to believe what you will. My suggestion to you is go for it and come back and let us know how you got a 500HP, NA, streetable engine from an OHV small block.
Car: 1992 Camaro RS
If that's your idea of cheap... go for it. You cant afford $1100 for a shortblock but you're spending twice that much on top end? The best way to make 500 streetable hp is to go Gen III/IV and even thats kinda pushing it.
You're gonna trash the T5. Get a TKO or a T56.
BTW, valves are pertty expensive.
Car: 88 IROC-Z
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
