TPS? MAP? MAF?
Old Apr 1, 2011 | 02:36 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
TPS? MAP? MAF?
Can somebody post a pic or try to explain to me where all these sensors are on my 305 TBI V8 Camaro? Please. I have no clue. And in the air cleaner I see a little plastic thing sticking up with 2 wires connected to in underneath the base of the air cleaner housing. My idle sometimes surges a 100 RPM or so when In park. I need help. Maybe the sensors need cleaning. Please help
Old Apr 1, 2011 | 02:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TPS? MAP? MAF?
TPS is on the throttle body, MAP is on the firewall, MAF is on a TPI car.
Old Apr 1, 2011 | 03:12 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: TPS? MAP? MAF?
what he said, you have no MAF on a TBI car
Old Apr 1, 2011 | 03:17 PM
Re: TPS? MAP? MAF?
Where on the firewal is the map? Doesn't it run to the engine to get the manifold air pressure. and what is the little plasic cone thing that is sticking up from the air cleaner housing?
Old Apr 1, 2011 | 07:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: TPS? MAP? MAF?
Inside the air cleaner is the IAT (Idle Air Temp) sensor.
If you mark a spot 1/2 way between the distributor and the heater box, attached to the lip of the cowl, there is a square flat black gadget - that's the MAP - it has a vacuum line to it and a connector.
Old Apr 2, 2011 | 04:40 PM
Re: TPS? MAP? MAF?
Is there a way to clean any of those?
Old Apr 2, 2011 | 06:32 PM
Car: 1992 RS
Engine: Carbed 350
Re: TPS? MAP? MAF?
No, just replace both MAP and IAT - not expensive.
Old Apr 2, 2011 | 07:06 PM
Re: TPS? MAP? MAF?
Cool, Thank you
Mark_ZZ3
May 24, 2018 01:02 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
