Idling in drive, sounds like a pebble in an aluminum can.
Old Apr 1, 2011 | 06:41 PM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
Mostly happens when I sit at idle, in drive with brake on. Best way to describe it is if you put a pebble in a aluminum can and shook it around. Once I start to roll and accelerate it goes away. Just doesn't sound right. Also it will start to idle erratic and eventually die if it idles for more than a few minutes. Other than that the car sounds very healthy.
89' Iroc-z 350 TPI
Old Apr 1, 2011 | 06:51 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Idling in drive, sounds like a pebble in an aluminum can.
Sounds like pinging, check your timing and check for vacuum leaks.
specialized
Jun 18, 2022 09:26 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
