Cold starting
Old Apr 4, 2011 | 03:42 PM
miketbodo's Avatar
Cold starting
It seems that if the temp is below 60, my 89 camaro won't start right away. I replaced the IAC valve this weekend, which helped it idle better when it warms up. I read in my manual that there is a cold start valve. Don't know if that is the problem. Any help would be GREATLY appreciated.
Old Apr 4, 2011 | 03:50 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Cold starting
What do you mean it won't start right away? DO you mean it cranks for a long time before actually starting?
What about after it has been running?
I ask because it may be the same problem I'm having.
Old Apr 4, 2011 | 03:53 PM
miketbodo's Avatar
Re: Cold starting
Yes... it takes several cranks and a little gas pedal to put fuel in the carb and let sit. But yesterday it was 97 degrees and it started right away. After I drive it, I can turn it off and start it right away.
Old Apr 4, 2011 | 03:55 PM
chevydrvr's Avatar
Re: Cold starting
I've never driven my car on a hot day (haven't gotten one yet haha) My engine is fuel injected TBI. I wonder if it's just normal.
Old Apr 4, 2011 | 03:58 PM
miketbodo's Avatar
Re: Cold starting
I never had that problem last winter/spring. It would start right away. I have the 2.8L, V-6. I spent 15 minutes at work trying to get it to start. I am thinking to replace the cold start valve, but want to make sure.
Old Apr 4, 2011 | 07:52 PM
HUSSAIN's Avatar
Car: IROC-Z
Engine: 377
Re: Cold starting
HOPE GUYS WILL HELP YOU
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
