Will this combination be ok?
Old Apr 4, 2011 | 04:29 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Hi all,
Im in a situation where I have a 406ci motor, with 210 full CNC ported heads, JE pistons which give 8.5:1 compression. The reason for this, is that the motor is built for the procharger I have. At the moment, Im not going to use the blower or EFI setup I have, mainly because of the cost of finishing the whole project.
I want to now run it N/A with a carb. I was thinking of using a Performer RPM manifold with a Holley 750, this will keep things simple and costs down.
I do realise, this is not an ideally matched combination, but for now will this work adequately, or not?
Also I dont have the specs of the cam, but do know its a Lunati solid roller blower cam.
Any help would be much appreciated.
Old Apr 4, 2011 | 08:20 PM
HF_monster's Avatar
Car: 86' z28 (died 5/1/11) 76 k10 pickup
Transmission: th350
Axle/Gears: 3.73 open
Re: Will this combination be ok?
With a solid roller and that low of compression that motor is going to be a dog just get yourself a mild hyd cam if your going to run it with out the procharger.
Old Apr 4, 2011 | 11:38 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
What he said.
Old Apr 5, 2011 | 06:01 PM
Car: '92 RS Camaro
Transmission: TH400
Thanks, I sort of guessed that, I will be using the blower in the future, so what spec of cam would be a good idea?
Old Apr 5, 2011 | 08:12 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
It's a 406 so you will use a fairly large cam anyway, but with 8.5 compression I would stay below 220 degrees .050 duration. Use wide LSA(110-112 degrees) to reduce overlap. Less overlap will help low speed drivability. Go high lift as possible to maximize cylinder filling for the best power.
Old Apr 6, 2011 | 02:17 PM
Car: '92 RS Camaro
Transmission: TH400
Thanks, this is really helpful Can you think of an off the shelf pattern that would be good? I looked at a Comp cams 268 cam.
Old Apr 8, 2011 | 01:41 PM
HF_monster's Avatar
Transmission: th350
that should work. Just make sure the springs you have on the heads are not going to kill the cam only takes a few min. to change them any way.
Old Apr 8, 2011 | 06:07 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
What he said. An old trick we used to use was to remove the inner of our dual springs for the break in. also, use a good break in oil with added zinc to prevent early lobe failure. God I love roller cams.
Old Apr 19, 2011 | 07:25 AM
Car: '92 RS Camaro
Transmission: TH400
So if I came up with the cash for a hydraulic roller cam, could I keep the springs I have?
InfernalVortex
Apr 20, 2021 11:31 AM
Hawk312
Aug 22, 2017 08:55 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
