91 firebird sputtering
Old Apr 6, 2011 | 10:45 PM
6String's Avatar
Car: 91 firebird
Engine: 3.1 liter
I have a 91 firebird 3.1 v6 that is sputtering while at idle or while cruising down the road. It doesn't die. The car starts just fine every time. When I give it alot of gas, it takes off just fine with no sputtering. I have changed the fuel filter, the plugs and wires, and my cap seems to be fine. (that I can tell anyway). the only codes i have are for the 02 sensor, and for my Tachometer. But the engine light is not on. Im not sure where to start. Mechanical problem? Electrical? Fuel? my gas is Good. No water. Thanks for your help!
Old Aug 15, 2012 | 09:06 PM
Rhemsis's Avatar
Car: 1991 Firebird
Engine: 3.1L LH0
Re: 91 firebird sputtering
Not to resurrect a dead thread, but I'm having the exact same problems as you were/still are. Same year, and engine.
The only thing I've noticed that differs from your original post is that on the initial startup, my exhaust has a slight blueish tinge to it, characteristic of burning oil...or so I've read.
I have a smooth startup, like mentioned in the original post, but after driving for about 10-15 minutes it develops a 'sputtering' during acceleration, and at an idle, that slowly progresses into what seems like a misfire.
I had a spark plug wire fall down, and get burned on my exhaust manifold. It didn't burn all the way through the wire, but the point of contact where it had laid on the manifold was stiff, so I changed the plug, and wire earlier today.
If anyone has any input, it would be greatly appreciated. I apologize for the lengthy post, but I thought the more details the easier it might be to diagnose.
Old Aug 16, 2012 | 01:08 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Get a manual and read up on all the components that make up the engine management system. Then start checking them. Check the fuel pressure. Test the injectors. Unless they have been replaced relatively recently there's a good chance the injectors need to be replaced and the fuel pressure regulator needs to be rebuilt. Once they are done you have a good base to start with.
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
