Losing spark!!
Old Apr 8, 2011 | 08:11 AM
hr1909's Avatar
Losing spark!!
I have a Speed Density TPI and I am losing spark while the car is on. The tach will all of a sudden move up and down and the car will try and turn off. Usually if i give it gas i could keep it on but if it turns off it will take a while to restart. The car has a MSD ignition and a large cap HEI distributor. Please help.
Old Apr 8, 2011 | 10:43 AM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
Re: Losing spark!!
if the tach is bouncing it's your pickup coil in the distributor.
Old Apr 8, 2011 | 12:42 PM
hr1909's Avatar
Re: Losing spark!!
what about the ignition module?
Old Apr 8, 2011 | 01:19 PM
theNMBR27's Avatar
Re: Losing spark!!
if the ignition module wen tout you would have a hard time starting the car when it was hot or it would just cut out completely. the pickup coil causes the tach to flutter. you car should have a small cap dist since it's tpi, did you swap in the hei or did the PO?
Old Apr 8, 2011 | 01:28 PM
hr1909's Avatar
Re: Losing spark!!
It was origanally a 86 block which used the large cap HEI. The whole distributor is less then a month old but it barely started doing this. It will take about 10 minutes to restart once it cuts off. What would cause either one to go out? which is more likely?
Old Apr 8, 2011 | 01:29 PM
theNMBR27's Avatar
Re: Losing spark!!
no hot start is definitely ICM go replace it and come back with an update.
Old Apr 8, 2011 | 01:31 PM
hr1909's Avatar
Re: Losing spark!!
sounds good. the tack doesnt like go crazy it just moves cause its losing spark I think.
Old Apr 8, 2011 | 01:43 PM
hr1909's Avatar
Re: Losing spark!!
Will the ICM cut off the injectors? cause when its not starting I have no injector pulse or spark!
Old Apr 8, 2011 | 04:23 PM
jwohlf's Avatar
Re: Losing spark!!
I'm having kind of the same problem. I have pulse and spark, but its faint. My car will start just fine, but if i turn it off and try to restart, it will crank but not fire up, unless i wait 7 or more minutes.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
