Help with spark problem
Old Apr 9, 2011 | 05:17 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
350 chevrolet computer controlled distributor
I don't think I'm getting any spark with it, I don't know for certain. I didn't feel anything holding one of the plug wires in my hand.
I switched distributors (with one that worked last time) and it's the same thing.
The engines out of the car. For the ignition wire I have one end clamped to the positive battery terminal and the other to the part labeled "BATT" on the distributor. the wire has 12 volts without crank and 10 volts cranking. I don't understand need help.
Old Apr 9, 2011 | 11:47 PM
Roy91's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Re: Help with spark problem
try getting a spark plug tester it easily shows you if your getting a spark or not
mddaniel
Sep 8, 2015 05:16 PM
db057
Sep 4, 2015 07:57 AM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
