wont start unlessed bypassed?
Old Apr 13, 2011 | 12:26 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Ok so i have had problems with my z28 at first it was the fuel pump so i replaced and it started for its first time in three years then i found out it wouldnt idle so i fixed the tps and idled great. But now i have another problem the car wont start unless i bypass the starter and start it manualy what could be the cause of this problem any help i would appreciate or if i need to give more info as well.
Old Apr 13, 2011 | 02:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: wont start unlessed bypassed?
Sounds like maybe the starter enable relay is bad - it's usually under driver side dash, sometimes behind the black goo at the hood release - should have a large yellow, small yellow, large green and a black with yellow stripe wires (4 total).
Old Apr 13, 2011 | 02:29 PM
Car: 1992 RS
Engine: Carbed 350
Here's a great aricle on the starter and troubleshooting:
http://www.austinthirdgen.org/index.php?pid=38
Old Apr 14, 2011 | 12:59 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh ok thanks im taking electrical classes right now, and next week were gonna go over how to learn to see the diagrams since right now i dont know how to understand the diagrams at all , but thanks for the link i will check that right once i learn how to read those diagrams.
Old Apr 14, 2011 | 01:04 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
could be the relay, or the solenoid itself. working at an auto parts store the solenoid is usually the case. hope this helps.
Old Apr 14, 2011 | 01:17 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh alright thanks ima check the relay first since that would be the easiest were is it located at do you happen to know, and how would i check the solenoid?
Old Apr 14, 2011 | 01:23 AM
jeff_blake's Avatar
alot of times if u take a screwdriver to the posts on the solenoid and it fires up, means the solenoids bad if you had to bypass that.
Old Apr 14, 2011 | 01:28 AM
jeff_blake's Avatar
most older fords have an external solenoid instead of one starter mounted and those are known to fail as well, as far as the relay location im not actually to sure.
Old Apr 14, 2011 | 01:31 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Well we bypassed it by the wire that goes toward the solenoid would it be like the same thing?
Old Apr 20, 2011 | 06:28 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Alright well i tested the starter and already and it was all good so any other ideas of what it could be?
Glowsock
Jul 24, 2025 03:15 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
