HSR setup with lt4 hotcam wont idle smooth, injectors or something in the tune?
Old Apr 13, 2011 | 01:10 PM
91formula-fbody's Avatar
Car: 1991 pontiac firebird formula
Engine: 5.7L HSR, 58mm tb,24lb inj.,lt4 cam
Transmission: 700r4,3000 stall,stage 2 shift
Axle/Gears: 10bolt 3.23 ratio
for some reason when the car is cold it will idle just fine in park or in gear but when it warms up it kinda has a miss and jumps 100 to 150 rpms irraticaly, the guy who did the tune said it was probably a injector sticking so i went too the junk yard and pull an exact set with same ohms and for some reason when i switched them out the idle dropped 100rpms, smells like a rotten egg kinda and the idle is more irratic now? any oppinions would be greatly appreciated
Old Apr 13, 2011 | 03:37 PM
Re: HSR setup with lt4 hotcam wont idle smooth, injectors or something in the tune?
somebody please???? im goin crazy over here about too set this thing on fire and call it a day
Old Apr 13, 2011 | 05:34 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Well, your first mistake was getting a set of injectors from a junkyard. Take the plunge and get a new or reman set. There are a couple of vendors on this site that will set you up. Some things are fine from a junkyard. Injectors aren't one of those things.
Old Apr 13, 2011 | 08:02 PM
ok ty for the info
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
355tpipickup
Aug 13, 2015 07:35 AM
