best way to adjust lifter/valves
Old Apr 17, 2011 | 05:12 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
got it running . it sat for two years, im not sure if they put new lifters and stuff in it while they had motor apart. but i figured the lifters would pump themselves up well that aint happening. so wat the best /quickest way to do this?
Old Apr 17, 2011 | 08:04 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: best way to adjust lifter/valves
I thought generally you soak each lifter I oil before you drop them in to help fill them.
What I've done in the past is use a tool that is basically like a distributer shaft that will spin the oil pump WITHOUT touching the cam gear. The top of the tool sticks out of the distributer hole and is attached to a drill. You take the valve covers off and watch for oil to weep out of all 16 pushrods. I remember I must of had one stubborn lifter because it took a long time for it only that one to prime.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
