fuel pressure help!
Old Apr 17, 2011 | 05:26 PM
jh7823's Avatar
Car: 87 camaro iroc-z
Axle/Gears: borg warner 3.27
fuel pressure help!
what should the fuel pressure be on my 87 iroc with the 350? i ust tested it and it runs about 35psi at idle then if u rev it its at about 40psi seems little low to me but is that normal?
Old Apr 17, 2011 | 06:59 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: fuel pressure help!
With a fuel pressure gauge on the schrader valve, and the vacuum hose on the regulator off and plugged, you should read 43.5lb at idle.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
