Do I need to go to a colder plug?
Old Apr 18, 2011 | 04:40 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I pulled all my plugs out today and I'm definetly running rich, but the ground strap on all of them is white. All the way to where the strap is welded on to the plug. I saw on one site where the strap should be white only from the tip to about where it starts to bend down. I really want to start tuning the motor better. I'm going to re jet the carb tomorrow and put new plugs in it, but not sure if I should drop down a heat range. I'm running NGK plugs right now, heat range 6.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
