Spark, and gas. But no fire.
Old Apr 20, 2011 | 04:48 PM
ConnorRexilius's Avatar
Car: 1982 Pontiac Firebird
Engine: 305 V8
Recently on my newly acquired 82 firebird, i have changed the spark plugs, cleaned the distributor and rotor, tested the ignition, triple checked the firing order, checked the spark plugs for spark, checked the gas, and poured some gas into the carb, but still it will not fire. Im a little dumbfounded. Any ideas?
Old Apr 21, 2011 | 11:51 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Spark, and gas. But no fire.
Compression test?
Old Apr 21, 2011 | 03:42 PM
Engine: 305 V8
Whats that and how do i do it?
Old Apr 21, 2011 | 04:38 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
compression test is a test to check the compression of the cylinders. Have you verified that you get spark at the plugs? not just check the cap and rotor and coil with a meter but visually see the spark plug working?
Old Apr 21, 2011 | 04:39 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
if you take the plug out and ground it. what color is the spark
Old Apr 21, 2011 | 04:44 PM
74Novaguy's Avatar
Axle/Gears: Stock
Has this car ran? if so what changed or what did you change? or did it just not start one morning?
Old Apr 21, 2011 | 05:50 PM
Engine: 305 V8
Yes, i have tested the spark plugs and they do spark. And, the car hasnt ran in, probably 4-5 years. I have only had it for a month.
Old May 4, 2011 | 09:11 PM
Engine: 305 V8
So after running a compression test, 6 of my cylinders are getting 170-175 psi and another 2 are 90-100 psi. What does that mean?
Old May 4, 2011 | 09:26 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
are you sure the plugs are not totally fuel fouled?
Old May 5, 2011 | 11:52 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
timing? almost sounds as if your 180* off.
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
